I need some plug recomendations
Old 02-13-2005 | 10:11 PM
rustbird's Avatar
Car: 92 firebird
Engine: A small block something?
The heads are dart pro 1,s angle plug,sbc,N/a,flatop pistons.
need sizes,heat,brand recomedations.
Thanks in advance
Keith
Old 02-14-2005 | 03:11 PM
Damon's Avatar
Lots of aftermarket aluminum heads these days are going to a plug type that uses a gasketed seat, long-reach threads but still the small 5/8" hex head. If your Pro 1s are relatively new (last few years) they will use this style plug.
Recommendation: Autolite 3924 or equivalent is what I use in my Darts and AFR heads. Also, check out Dart's website for plug recommendations which, if I remember correctly, will exactly cross-reference with the Autolite plug I listed, above.
Old 02-14-2005 | 03:46 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
IM using those same autolites (3924) in my Trickflows. And after a little plug reading. The heat range is pretty close. I like them better then the ACs i was using before.
Old 02-14-2005 | 04:59 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Nice avatar.
Old 02-16-2005 | 01:46 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
Always start with a cold plug. It's better to foul out $10 in plugs than preignite and destroy an engine. I'd start with Autolite 3923 or Motorcraft AGSP22 (same plug, different stamp), put a couple miles on them and then if they're fouled go up one heat range to 3924/AGSP32. The insulator should be a light tan color. If it stays white you're too hot.
gta892000
08-11-2019 12:16 PM
wigmobile
09-17-2015 04:38 PM
92rsvortec350
09-10-2015 11:54 AM
Jlanz55
09-09-2015 10:09 AM
89 formula TPI
09-07-2015 12:06 PM
