Need help quick
Need help quick
Fouled PLUG QUESTION:
Ok I am about to take a road trip and i decided to change the plugs first.. my #8 plug has some serious ash on it... I was running a HR9BP Bosch Platinum Plug... All other plugs are fine and I suspect this has something to so with my Valve Seals since i get a blue puff at startup.. My Question is should i run a hotter plug and if so which one.... I cant use Delcos because of the headers
Mike
88 Iroc-Z 350 tpi, Hedmann Headers, 3" Cat Back, MSD Ignition, K&N, AirFoil
[This message has been edited by mjdoyle (edited June 29, 2001).]
Mike
MJD,
If the plug already has ash on it (not soot or carbon) and no oily residue, the plug is hot enough. Going higher in range may only blister the insulator, but won't clean it any more. However, if there is still oily residue, a hotter plug might help. Going too hot can contribute to detonation.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Later,
Vader
Thanks Vader... so i guess the only solution is to finally get my valve seals replaced eh? Well i'll just keep an eye on that plug until then..
Thanks for the help
Mike
Mike
Thanks for the help
Mike
Mike
3.8TransAM
09-27-2015 08:37 PM
