fan in front of A/C condenser?
Car: yep
Engine: uhuh
Transmission: sure does
Some cars actually have them in front of the condenser stock.
It comes on when the A/C is on, this helps keep the condenser cooler at idle, making the A/C colder when in traffic or at lower speeds.
The bonus is the air will help the running temp too.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Guest
Posts: n/a
It should help. You can even fit 2 up there, a 14" and a 12". I'd mount them to the radiator support rather than using the zip ties to the AC condensor idea... And make sure the nut when it trys to fall off the bolt you have holding the bracket for the fan can easily do so rather than rubbing a hole thru the AC condensor core.
ambainb
04-25-2016 09:21 PM
Street Lethal
08-13-2015 08:28 PM
db057
08-11-2015 10:11 PM
