Best Budget Alum Cylinder heads
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Whats the best cylinder heads for around 1200bux that flow atleast 260 outa the box with .600 lift. Gotta be aluminum oh and has to be 58-64cc Combustion chamber volume.
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
You can get AFRs in that price range and IMO they are the best. They come in 68 and 74cc chambers but can be milled down to whatever spec you need if you want to run the same compression with the stock pistons.
Another important thing to look at is intake runner size. Look for heads that flow well without having a port larger than you'd need. Lots of heads flow 260 but few do it with tiny ports. Something to consider.
Trevor
Trevor
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Fastburn? No way, they have huge runners and are not what they are cracked up to be.
1 Post
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Have you looked into Canfield heads? http://www.canfieldheads.com/sbc.html
They appear to flow really well. I talked to them a couple of weeks ago and you can buy their 195cc (197cc) intake runner heads for $600 or $700/pair bare, just call them. Their 195cc heads accept standard offset rockers, but their 220cc heads are offset, if I'm not mistaken. These are the same heads as the Jegs heads http://www.jegs.com/cgi-bin/ncommerc...50&prmenbr=361 but without the Jegs stamped in them.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Competition Products sells Canfield 195's for $1055 with solid-roller worthy springs.
An extremely underrated, under-used head. I'll be purchasing a set very very soon.
Car: Death Mobile
Engine: 666 c.i.
Actually, a buddy getting a set of AFRs (Sean aka GTA in Manitoba). I cautioned him that AFR was notorious for charging for every little thing and "nickel/diming you to death".
However, as I recall, AFR did all the accessory holes for the list price. The only thing they charged extra was for milling the heads down and heli-coils.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Car: '89 IROC-Z
Car: Death Mobile
Engine: 666 c.i.
Lets not forgot you'll be waiting for months just to get the heads directly from AFR... Of course you could buy them from other suppliers but if you need something special, have fun waiting. Regardless of if they're a great head or not, when you factor in the long wait + all the addes costs they just dont seem that great.
Not sure if it's because AFR has a large back log (because everyone else wants to do their engine mods during winter) or if they have something wrong with their prodution line.
Funny thing, my other buddy sent his heads back to AFR in early December for some extra work and got them in a couple of weeks.
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
1 Post
Car: 91Z28 L98
Engine: HSR 350
They will sell them either way. I know when I talked to them (Competition Products), they were $700 bare. That price is for the pair. http://www.primediapowerpages.com/cg...0216&2D1007259
I know the site says that price is each, but I talked to both Canfield and Competition and both said that price was for the pair (bare). Competition told me that the guides are installed on the bare pair, but they will need to be burnished and the seats cut with a serdi.
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Yup that's me.....AFR ...100 days from order to confirmed built....I just hope that they are worth it.....I do not mind a wait but this was a bit much.. hopefuly someday soon AFR wil be able to better keep up with demand
Chuck84TA
07-15-2016 09:05 PM
NinjaNife
08-23-2015 11:49 AM
