To anybody with a cooler fan switch...
1 Post
Car: yep
Engine: uhuh
Transmission: sure does
I need to find a fan switch for a TPI that comes on lower than 180'
I need to know if someone makes one that comes on about 160, 170 range.
Any help is greatly appreciated, if you have part #s, thats even better.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Definitly, i believe TPIS has them in their catalog, and Scoggin's Dickey i believe has them also. I'm sure there are others but they are slipping away from me right now.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
Car: 1987 Z28 Convertible
Transmission: 5-speed
The problem with all the aftermarket switches, especially the low temp models like Hypertech and Jet, is that you cannot turn them off. You do not need such a low-temp switch during the winter.
Go with a Hayden 3647 as outlined in my article on this website. It's an electronic module that's adjustable from 160 to 210. Just don't wire it as per the instructions. These instructions are geared to add an electric fan to a vehicle that does not have one. E-mail me for instructions on how to wire it so you do not defeat ECM control of the fan, yet retain full adjustability through the Hayden module.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig): 12.57 @ 111 mph.
Former Paxton (6-psig) & former 50-hp nitrous: 12.04 @ 114 mph.
ATI D1SC (5-psig):
12.26 @ 113.55 mph
ATI D1SC (10-psig): Projecting high 11's.
Future ATI D1SC (15-psig): Gotta catch them pesky 26-psig boosted TTA's!!
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
[This message has been edited by Willie (edited June 16, 2001).]
Willie
ATI D1SC (5-psig):
12.26 @ 113.55 mph
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
If you have an Autozone parts store around there, go buy the $20 adjustable switch from them! It's simple to hook up... splices into the wires coming off the fan and uses a temp probe that you attach to the radiator! I use this switch and it works great! In the summer I use a 160 t-stat and in the winter I put in the 180 t-stat.... this adjustable temp switch allows me to just simply turn the **** and adjust when the fan comes on depending on the temp t-stat that I'm using! Trust me, it's well worth the $20 for it's ease of use and versatility... not to mention that it's cheaper than buying a cooler replacement temp switch!! Also, if I'm not mistaken, the stock fan switch is located in the passenger side head and is not the easiest sensor to get to!! Oh yeah, if you buy this adjustable switch and someone tries to tell you that you need a relay to hook up with it, ignore them because the adjustable switch has a built in relay so you don't have to worry about hooking one up!
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Current Project: upgrade to a 355 TPI, 6" rods, 9.5:1 Compression, Stock TPI ported, 24#/hr LTI injectors, Hedman Shorty Headers, SBC Stock Casting heads pocket ported, Comp Cams XE262-14 TPI Cam, Ed Wright Fast Chip, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Box, Hypertech hot coil!!
1986 Trans AM
305 TPI
4 Wheel Discs
Completely Stock
1 Post
Car: yep
Engine: uhuh
Does anybody have a part number for the switch or adjustable controller??
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
<font face="Verdana, Arial" size="2">Originally posted by Engineboy:
</font>
</font>
1986 Trans AM
305 TPI
4 Wheel Discs
Completely Stock
1 Post
Car: yep
Engine: uhuh
Cool, that would be great.
Thanks,
Bill
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Thanks,
Bill
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
I bought the CSI adjustable Gauge. I had the derale first and it didnt work very good. It has a probe (sensor) that goes in the radiator fins. The CSI gauge screws into the head or intake manifold for direct contact with the water. The Gauge is adjustable from 100-300 if I remember right. It will dim with your headlights for night use. It also keeps track of the Highest temp since the key has been on.
Sorry it took so long to get back to you! The adjustable fan switch that I'm using that Autozone sells is made by Imperial Automotive Products and the part number is 226203
Hope this help!
Hope this help!
1 Post
Car: yep
Engine: uhuh
Thanks man, I saw one at Carquest and it was $107.00 !!
I'll let you know how it goes...
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
</font>
</font>
Well the one I have cost me $20 and it's nothing fancy but I've been using it for over 2 years now with no problems other than having to replace the power wire after about a year because it was too small! Save yourself the future pain and get thicker wire... I think I'm using 14 gauge.... that or 12 would be what I would suggest... and make sure you fuse it, I can't remember for sure but I don't think it comes with a fuse!
1 Post
Car: yep
Engine: uhuh
Cool, I'll do that, thanks.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
