Plain / Neg. EGR Valve Number Needed
Car: Caprice
Engine: 5.0 305 LO3
Transmission: 2004-R
Positive / Negative EGR Valve Number Needed
Hi, I got the common code 32 after installing true dual exhaust on my L03. I was wondering if anyone has part numbers for either a negative valve or plain vacuum valve that has worked for them. Thanks,
Adam
Adam
1 Post
Car: 1991 Chevy Camaro
Engine: 305 TBI
I haven't swapped to true duals or anything, but I bought a replacement EGR valve for my car not too long ago. It is a negative backpressure EGR valve, and it's AC Delco part number 214-5575 and GM part number 17113496.
Car: Caprice
Engine: 5.0 305 LO3
Thanks guys. Ya I looked at that picture in my fsm. The egr and solenoids in themselves work, but the exhaust is not allowing them to do the correct thing in OD. Thanks for the number, I'm going to go check it out.
Car: Caprice
Engine: 5.0 305 LO3
Well, I finallly looked closely at my "stock" egr valve and the GM part number on it is 17088125. It is a negative egr valve. The motor is an LO3 and according to ACDelco.com, the part number is a little different. Well I guess I will have to check my egr solenoid and intake passages now. Or try a different valve for my low backpressure dual exhaust. Any other ideas? I've already tried a '96 Z28 Camaro negative backpressure egr valve and that didn't work.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
