Bad Miss @ higher RPM's
1 Post
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey Everyone,
Im having a problem with my 91 RS 305TBI. The falls flat on its face once I hit 3000-3500 rpm. During normal driving, you wont notice anything becides the car running a little rough. But as soon as you get on the gas, the car will rev up to about 3000 rpm and then will not want to rev up any farther. It will slowly climb till the tranny shifts. If I let of the gas at any time while this is happening, the car gets a quick surge of power to the wheels. I have been having problems with my headers burning through the spark plug wires so I decided I would replace them before I bugged you guys, but I put a set of new 8.8 mm Accell wires on the car along with an Accell Cap & Rotor and the car is still acting up. The coil & A/C Delco plugs are about 6 months old.
I am starting to think this is fuel related. I will probably put a new fuel filter on it and check the fuel pressure this week.
1 Post
Car: "02 z-28
Engine: LS-1
Definitely check fuel pressure. I had a problem recently with start up, ran rough then died. Fuel filter was completely plugged. The fuel additives used today are causing many types of problems. Replace the fuel filter once a year. Otherwise use normal troubleshooting.
Car: 4
Engine: 6
Transmission: 5
Yup, definitely look at fuel pressure, AT THE TIME IT'S MALFUNCTIONING; not just sitting idling.
If it's OK (12-15 psi), then it's probably a broken valve spring, on an intake.
backtothe80s
09-05-2015 12:39 AM
eightsixseven
08-14-2015 03:09 PM
