World Industies Torquer Heads?
I was thinking about having my heads worked on because my valve guides are messed, then I come across an add for the World Industries Torquer heads. They cost only around $400. Would these work well with my LB9 305tpi? With a price that low why would I even rebuild the stock heads? Anyone got em?
thanks
thanks
World Products makes a head for the 305 with the necessarily smaller valve sizes. The World S/R Torquer 305 has 1.94"/1.50" valves, 58cc combustion chambers, and 170cc intake port volume. The chamber size is stock, the runner volume is larger, and the intake valve is 0.100" larger than the stock valve (about the largest you can squeeze into a 305 unless you're very crafty). The S/R 305 heads I've seen advertised are all cast iron, not aluminum. I would hesitate installing 350 heads on a 305 due to the possibility for valve interference. The $400.00 price is likely for stripped heads. Complete heads with valves and springs are usually around $800.00.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Later,
Vader
"Make Me Bad"
Are they worth the money, or would I be better off spending it on something else? My car ran a 15.4@89mph, I am looking to improve that before next year.
thanks
The Torquers are great heads compared to stock. Get the 305 Torquers. They are like stated above, smaller chambers,etc. For a 350, get the S/R Torquers or go all the way for the Sportsman II's. World Products makes a great aftermarket sets of heads.
Good luck!
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Edelbrock 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Good luck!
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I spent a good bit of time corresponding with Competition Products about these heads. The price is about $650 assembled with shipping (at least shipping to Colorado). That is the best price I've seen from anyone for those heads. Everything I've heard is that they're worth it, especially if you have to spend $400 on stock heads anyway.
The 305 heads are S/R Torquers, and therefore higher priced than "regular" Torquers.
Pop in a better cam while you're at it to take advantage of the better heads.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 3.08 open, cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, World 305 heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
True, they are S/R Torquers, but there is S/R Torquers and S/R Torquer 305's....just when ordering he needs to know there is a difference. Check them out at http://worldcastings.com/
Just clearing the cloud....but $650 assembled and shipping is a great price.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
1 Post
Car: 1992 Z28
Engine: 355
Is it my ad you saw in the want ads somewhere(nethirdgen,camaroz28)?Anyways , mine are SRT 350's.If you can find them for $400 dollars COMPLETE i'll kiss your *** .These heads worked very well on my Z28.Mine have been ported however.
Paul Bab****
92Z28
89GTA
Paul Bab****
92Z28
89GTA
Engine: LS1/LQ4
I got it backwards. There are S/R's ("stock replacement"), and S/R Torquers. The 305 heads are S/R Torquers only, even though the valves are only 1.94/1.50. So, it is the higher price.
I just got a new Jegs catalog today. They say "not torquers" for the 305 heads. That's wrong, but it's still the higher price.
Beefy89, I assume that's for a pair and doesn't include shipping. I also asked for better springs (standard not good for over .500 lift). And, again, the 305 heads are sold as Torquers, so the S/R price doesn't apply.
I think we'd all agree that they're the heads to use.
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
woah, The latest issue of "Camaro Performers" did a build up of a 1985 IROC 305 TPI engine.
All they did was install these World heads, but it gave them like 60-80 more horsepower as i recall, but it looked like it places the max HP at a much higher than stock 5,000 RPM. Sounds worth it just for that!
I also remember seeing a Cam in summit, for TPI 305 camaros, which gave it "40 more horsepower". Think if i added both of these mods to my 1986 TPI "LB9" engine, i would be in the range of 300 horses? that isn't too bad, i might be able to enjoy the 305 untill i get the 350 that way too.
Also, anyone know how much it would typicaly cost to have a shop install the heads and new cam?
Thanks guys!
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
Doesn't know enough about cars.
AIM: jesusathome
Thanks guys!
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
AIM: jesusathome
1 Post
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
the day you see 300 horses from heads and a cam on one of our 305s is the day i kiss your *** . do the work yourself and save a ****load of cash. it isn't very tough. I did the cam, can't imagine heads being much more difficult.
92projectcamaro
01-18-2016 08:00 AM
