How much freon does a 87 Trans Am Hold??
I'm converting to r-134a and don't know how much to put in. They say 85% of what the system holds of r-12 but I don't know whow much that is. Does any know? My car is here at the shop now and that's all I got left to do. Thanks, Jason
JAS,
I'm not sure if they are exactly the same, but my '86 TA takes 3.75 puond of R-12.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Later,
Vader
Car: 82 camaro SC
Holy ****, mine holds 2.25 of R12. The most I've ever seen a third-gen hold was around 2.75. Maybe you have a high-capacity system. It should be under the hood somewhere.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkim bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
The manual for my 1989 says that the system takes 2.25 pounds of R-12. I would think this should be pretty close to the same as an 87.
Later-
Mike
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber.
Later-
Mike
Car: '89 GTA
Engine: ZZ6TPI
48oz of R-12
40oz of R-134A(31.5oz refrigerant, 8.5 oz oil)
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Magnaflow cat-back,
K&N open element,
<font face="Verdana, Arial" size="2">Originally posted by TransamGTA350:
48oz of R-12
</font>
48oz of R-12
</font>
Later,
Vader
Car: Take
Engine: Your
Transmission: Pick
Your system holds 2.25 lbs of R-12. When I do thirdgen conversions, I put in 2lbs even. The general rule of thumb is 80%, but it is used as a STARTING POINT, you can add more to acheive the desired pressures, wich is about 2lbs. Its tried and tested, go with it.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Re: How much freon does a 87 Trans Am Hold??
Amazing to keep this site around. 20 years later, this thread helped me! Thanks TGO!
Bow_Tied (06-30-2021)
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
