Federal mogul bearings (Speed-Pro)
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Looking through the federal mogul online catalog for main bearings I came across two options.
O.E Replacement P.N 4663M and
Competition Series P.N 139M
I'm assuming the O.E replacement (Copper-lead material) are the ones I want, because it's a standard 383. The competition series are made from a differnt alloy and have a 3/4 groove. I assume thats for a high-volume oil pump? I hate to assume, so I'd thought I'd ask. Out of curiousity would a competition bearing be used more on circle track?
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The competition bearings have 3/4 oil grooves. This allows oil flowing to the rods at all times during rotation.
I like the 3/4 groove bearings better than the full groove Clevite 77's because there is more bearing surface.
Car: 1986 Iroc
Engine: Afr 408
I guess thats kinda why I'm looking at the FM, too many people talk about Clevite's quality issues. So I got the right bearing manufacturer down. Next is choosing which ones.
Five7 - what kind of engine did you use the 4663's in? street/strip type motor? rpm range? power output?
One half of the bearings have a groove thats fits in the cap or block, I can't remember. So on the competition bearins, the 3/4 groove would extend into the other half? If they supply more oil to the rods wouldn't you need a high volume oil pump? My guess would be because of the higher rpm that they would need more oil. I'm not really sure. I plan on having my bearing clearances at stock spec. Maybe RB could shed some light on the subject...
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
The 4663m bearings are listed as a full groove in Summit.
Why can't I find any FM bearings that have the half groove? I don't need a high volume pump and full grooved bearings. I trust the very reliable SBC oiling system.
Car: 1986 Iroc
Engine: Afr 408
I went with the FM 139M bearings. They are 3/4 groove. I'm using a standard volume oil pump with a high pressure spring. Bearing clearances for the mains are .002-.0025 (I forget the exact numbers) and .0027 on #5. Rods are ~.002 (again forget exact numbers). Oil pressure is great, 60-70 psi cold start and about 40 psi hot idle with 10w-30, I might switch to 5w-30 and see how that goes. Couldn't tell ya cruising, because the car hasn't been outa the garage yet...
Car: 1991 Z28
Engine: 383
Summir lists the 4663m FM bearings as a full groove, upper and lower.
http://store.summitracing.com/partde...5&autoview=sku
And JEGS doesn't even list the 4663m's in their catalog....I would really like to stay away from Clevite for this build.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It doesn't matter what Summit calls them. Federal Mogul calls them half groove, and the sets I have laying around all agree.
Car: 1991 Z28
Engine: 383
I believe you and I don't want to start anything stupid but I would hate to order them and get full grooved bearings.
Is there a possiblilty FM changed the design or is there a difference between the 4663m's and the 4663's? I searched just for 4663 and didn't find anything.
Engine: 383 Carb
Transmission: 4L60
They don't have a "4663", just the "4663M". The "M" indicates that it's a kit of different bearings. It comes with 4 3201CP and 1 3202CP for the rear main.
[ON] 9 Bolt Axles Partout
6speedIROC
16
03-15-2023 09:33 PM
