What is a better wire auotlite or accell?
I bought a set of autolite wires for my car, but my friends said i shoulda got accell. But autolite is more exspensive, which i dont understand, help me out here.
87Camaro RS
305 carb.
K&N air filter
HyperTech Stage II chip
160 Thermostat
87Camaro RS
305 carb.
K&N air filter
160 Thermostat
Car: 1986 Firebird
Engine: 2.8 V6
Autolite might last you longer, but they're a stock wire. That means 15,000 ohms per foot of wire. Accels vary, but I think their cheaper wires are 5,000 ohms per foot. Less ohms = more spark to your plugs.
Plus, isn't the Autolite's insulation 7.5mm? With Accel wires, depending on the set you buy, you're at least getting 8.0 mm wires... more insulation = less "spark leak" through the wire.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
autolite is also a ford product, go with the accel 8.8 custom fits they are awesome!
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,TB coolant bypass ,polyurethane tranny and torque arm mounts, k&n oil filter,synthetic oil 10w30, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by Fastcamaro87:
autolite is also a ford product</font>
As for the wires, neither one. I'd get MSD or Taylor wires personally... But quite honestly there is no reason to replace what you have now unless they go bad.
Car: 88 Firebird WS6
Try the summit universal fit spiral core wires. $31 gets you a kit with the crimper to put the ends on (not really a big deal)
I've had real bad problems with accell wires and wouldn't recommend them to be used on a honda even...
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
'88 Camaro RS 2.8L
evilstuie
02-28-2016 03:33 PM
355tpipickup
Alternative Port EFI Intakes
08-26-2015 04:08 PM
