timing chain sprockets (non thirdgen, sorry)
Car: 87 IROC
Engine: 5.0
Hey guys I am having a little prob here, I am replacing the timing chain and guides
on a 91 toyota p/u 22re engine, (sucks), I
am having diffuculties sliding the chain sprockets on the crank shaft and cam, it is
very very tight, old ones came off farily easy but when I tried to install old ones on just to see they would not go on either,
anyone know of any tricks or hints.
Thanks for any ideas.
TPIS airfoil,relocated MAT,AFPR,TB h2o bypass
March Underdrive Pulleys
otherwise stock 5.0TPI
700r4, 10 bolt 3.23 g92 axle, 4 wh. disc brks.
1 Post
Car: yep
Engine: uhuh
Transmission: sure does
I can't offer any tricks, they just slide on.
I usually put a little grease on the inside of them to help them slide on, I have had to tap them on with a large socket before.
Good luck.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Good luck.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Car: 87 IROC
Engine: 5.0
Thanks engineboy, it worked out ok, a little
persuasion with a rubber mallet popped it on,
thanks. I'd rather do a timing chain on a
sb chevy than a toyota 4 banger any day,
yes he can see air, godspeed #3
[This message has been edited by MY87ROC (edited June 11, 2001).]
