Relieving Fuel Pressure
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Ok when relieving the fuel pressure it says to unplug the fuel pump fuse and let the car run until it dies. How long does the car usually run for? The car is an 87 Z with 5.0 tpi. We let it run for like 6 minutes and it still didnt shut off?
Huh? Your car ran for 6 minutes with no fuel pump? I can't imagine.
Last time I replaced my fuel filter, I didn't bother to relieve the pressure. I did open the gas cap to vent the tank to atmosphere, but then in the fuel lines I just put a catch pan under the old filter, loosened the fittings and let it drip for a minute. I lost about half a cup or so of gas, no biggie.
Car: 83 Z-28
Engine: LG4
Well that is what the Chiltons manual says to pull the fuel pump fuse and then start it up and then its supposed to run till its out of gas. I take the gas cap off too. I was just wondering why the car does not die since the fuse is not in.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you have a carb'd engine, its probably running off the mechanical pump. Some cars have both, like the carb'd cars.
All I do is take off the gas cap, and thats enough... works every time.
1 Post
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Uhh Adam, he says its a TPI engine. Not quite a carb setup
I am going to assume you are pulling the under-dash fuse, right? I'm with Tremo, not certain how it ran for 6 minutes. Maybe, just maybe, you yanked the wrong fuse?
Car: 83 Z-28
Engine: LG4
1 Post
Car: Z28
Engine: Sb2.2 406
Try popping the hood and looking near the battery/coolant overflow tank. There should be a 20a inline fuse there that protects the pump relay. Yank that fuse.
Might have to yank/disable/unplug the oil pressure switch as well.
1 Post
I missed that, and I saw under his avatar its said he has an LG4. My bad
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
The fuse under the dash doesn't do anything because the oil sending unit also sends current to the fuel pump over a certain psi. So it needs to be the relay in the engine compartment in the front right corner (well that's where it is on mine)
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
with my old RS, i tried to change the fuel filter and i pulled the fuse under the dash and it ran forever idling.. like ****... but it never died lol
with the iroc, i just do like tremo and pull the gas cap, and break lose the line for the filter and let it drain.
Car: 83 Z-28
Engine: LG4
The Chiltons does, I just don't think it's all that specific when it comes to tell you what fuse it's talking about.
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
I had the same thing happen when I went to replace my fuel filter. I idled real rough for about a 5 min. So I took out the other fuse below the fuel pump one (for the other injector). Then it finally died due to lack of fuel.
R3500
08-17-2015 12:16 PM
92camaroJoe
08-13-2015 06:07 AM
