Sounds like someone put in a gear drive while I wasn't looking!
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
My car has a non lockup 700r4 with a neal chance racing converter in it. Tonight I drove my car around for a while and into someones house for about an hour and a half. I came back out and get in my car, put it in reverse and I hear a whining sound. I thought that it was my richmond gears making some noise but it wasn't. I put it in drive and all the other gears and I still hear it. It sounds like a gear drive whining. I know it's not the rearend because I can hear it when it is stopped. I checked the tranny fluid and it looks good.
What is going on? It sounds really bad.
Car: 1990 Formula
Engine: 5.7 liter
it might of knocked your tranny out of whack from driving into someones house. I would be more worried about that man!! what happened?
click below to check out....
www.formula350.com
or click below to email me
webmaster@formula350.com
<font face="Verdana, Arial" size="2">I have experience......unfortunatly its a result of bad judgement......</font>
www.formula350.com
Have you replaced any parts? I remember installing a rebuilt water pump on my car, and the thing would whine. A friend of mine thought I had a blower under the hood. I've never had a water pump do that. It was weird.
Does the sound occur only in reverse? Does the sound increase with RPM's? Once, I had to back up rather quickly and the tranny (700R4) whined. It doesn't make the sound when going slow in reverse, though. Were you reversing quicker than you usually do?
I just re-read your post. I only heard my tranny whine going quickly in reverse. I'm not sure what it would be since you hear the sound in the other gears and while stationary. I would've guessed fluid level, but you already checked. Has the trans filter ever been replaced?
[This message has been edited by coach (edited June 03, 2001).]
my altinator sounded liek that im my old IROC, i put some grease on whe rear berring from th eoutside and it would quiet down a bit for liek 2 days.
try this remove all the belts from the accesories then start the car for like a minute just enough to see if you hear the wine, if yo uhear it its not any of the accesories and its either a gear drive or a internal problem
-Stell
1988 Pontiac Trans Am. 305 TPI Mods=MSD 6A+Coil+Wires, K & N, SLP AirFoil,180 Thermostat, Cold Air, Hooker Aerochamber Catback
1974 Dodge Charger , Currently restoring but has a 318 with Crane Cam, Carter AFB 4BBl Carb sitting on a Weiand Stealth Intake
RIP 1988 IROC-Z
http://stell15790.tripod.com/cars.htm
-Stell
RIP 1988 IROC-Z
Car: 92 Camaro RS
Engine: 305 TBI
Yeah check your alternator, I've had the diodes go out twice in mine, it would still charge some but sounded like I had a superchager under the hood, I had it fixed at a starter repair shop once for $40, the second time it went out I put in a IceBerg conversion kit with a back housing that has cooling fins on it and I have not had any more problems with it in 100,000 miles.
92 Camaro RS 5.0 5-Speed
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
3.08 Posi-trac
Crane cam
HyperTech Chip
92camaroJoe
08-13-2015 07:07 AM
