waterpump bypass
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
waterpump bypass
ok i've read some where(and i can't remember where)about plugging a hole where the waterpump mounts to the block.the hole i'm talking about is on the(this a 89 350 by the way)passanger side of the block right below the bottem mounting bolt hole for the waterpump.has any one done this and did you have any problems by doing this
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
[This message has been edited by 91banditt2 (edited June 02, 2001).]
Engine: 5.7 HSR
the coolant that goes through this coolant passage doesn't go through the wasterpump,it's supposed to direct all of the coolant through the waterpump
