Need help doing GM '870 -> GM '730 ECM SWAP!!!!!!
This is what I have:
GM '730 ECM with memcal & memcal prom adapter
MAP sensor
MAP knock sensor
Female wireharness header for '870 ecm (so can plug this to the stock male header)
3 wire harness for GM '870 ECM
Misc. Wire harness for MAP sensor
So I need some serious help from some guys/gals willing to help me do this conversion. I have the '870 ecm pinout description but it gets challenging looking at the '730 wiring and how to swap them together.
My goal is to repin the 3 '730 wire harness as necessary, wire them to the female '870 header, plug it up to the stock '870 male header in the car, misc wiring under the hood, install a prom and live happily ever after.
Easier said than done.
If anyone can point me to specific websites or provide detailed info i'll definetly appreciate it.
1985 355 S/R V8
MAP sensor
MAP knock sensor
1985 355 S/R V8
