Underdrive pulley HP gain?
I just got a set of steel billet under drive pulleys for my 1992 Camaro RS. Realistically, what increase in power should I see? And are there any tips you guys have for operation? I do have a stereo system in the car and I heard things like setting the idle higher, etc., so the battery charges...
Thanks!
_ _____________ _
1992 Camaro RS
Thanks!
_ _____________ _
1992 Camaro RS
Car: '87 FIREGOOSE!!!!
I don't really know a number of hp gain, but I put an airfoil, Hypertech II chip with fan switch and thermostat, K&N airfilter, and cut the screens out of my MAS sensor in all at the same time, then a year later, put a set of March pulleys on my car and niticed more of a seat of the pants difference with just the pulleys than with all the other things togeather. Now I know that everything works togeather to all help as one, but I am just telling you my experience with the pulleys is very positive for the money spent. For me it was one of the best bang-for-buck bolt-ons I did. Highly recommended, you definetly get a couple hp out of them, who knows, maybe 10-12 easy.
Location: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I think you will get mixed opinions on this. I was thinking about buying a set myself, but I'm not sure if they really are worth the money. They seem really popular with mustang drivers
1 Post
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
With a slightly modded L98 I saw just under 2 tenths and 2mph. Same track, conditions, weather, 60ft etc. I've seen similar results in other cars. I couldn't deal with the lack of charging/dim lights etc. Some don't seem to have the charging problems I did.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
if your conserned abotu charging problems you have 2 oprions, 1 get a high out altinator or 2 you could look at the pullies made by March. the Pwoer and amp series. it states in there catolog that it reduces accessory rpm's and raises the alternator rpms for poper charging. there a bit more expensive 2 piece 91.99 3 pice 171.99 ( in jegs) but there s an option for ya as well.
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear
91 camaro RS
- 305 TBI
You will see some power but you will also be asking for a jumpstart way to often if you run a your stareo at all. I sold mine after two weeks. Unless you have a T-5 or T-56 convert. they idle high enough to handle the drain.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,and just about every other bolt on that there is. Just got a ZEX nitrous kit!
Mine can't keep up with the electronics on a good day so I am scared to put a set on my car. I don't think they would work right. I have seen a 2000 S-10 with a set but the battery wouldn't stay charged.
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Personally I think they're an excellent addition to a manual tranny car. Most of them (as was said) idle high enough anyway, and some of us will probably need to keep the idle around 900-1000rpm anyway so it doesn't stall .
I'm not sure if I'd put them on an automatic car. Not enough control over the idle speed for me.
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro ZZ4 M5 (V-6 in a former life) -- street beast
'91 Medium Blue Metallic Z28 A4 (UB-HSTRY's old ride) -- currently broken
'99 Navy Blue Metallic Firehawk #120 M6 (99.44% stock) -- daily driver
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i've got the 3 peice billet aluminum($151 wheni bought them 3 years ago)March Power&Amp under drive pullies.other than it looking pretty(real pretty)i really didn't see any seat of the pants difference.
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Well, is it possible for me to set my idle speed higher?
If I get a high-output alternator, a battery with 1000 cold cranking amps, and a 1 farad capacitor for my amplifier, do you think I'll be alright with the pulleys in?
1992 Camaro RS 305ci TBI
Flowmaster exhaust
SLP cold air induction
Hypertech Performance chip
MSD 6A ignition
Macewen white faced gauges
Sony Xplod CDX-M610 head unit
Pioneer 4x6 and 6x9's
12 inch Polk/MOMO subwoofer
Kicker ZR360 amplifier
Coming soon:
125 HP NOS kit
TBI spacer
Hi-flow throttle body
Dynomax headers
MSD Adjustable Timing Control
Flowmaster exhaust
MSD 6A ignition
Coming soon:
125 HP NOS kit
TBI spacer
Dynomax headers
The magazine I looked at showed dyno results of the same car/conditions with regular and performance pulleys. The results showed an increase about 10 HP/ft lbs TQ.
A capacitor would definitely take some of the stress off of an alternator...but you still have to worry about headlights, radiator fan, etc.
bigjay89gta
10-15-2015 08:04 AM
