Parking brake a novelty!
Car: 1986 Chevy Camaro Z28
Engine: 4BBL 350
Hey, whaaatup.
So, my battery died the other day, and i had to push my car about 30 across a parking lot so that a charger would reach. Anyways, i pushed it over, and when i was done, i was thinking "Wow, that was kind of tough!".
I get in the car, and the parking brake is on! I was like, No way!
Got back out, sure 'nuff, the thing pushes around fine!
What can i do to restore my parking brake? The rear brakes are fine, however sometimes my mastercylinder shows lack of fluid, and I have to top it off. Do i have a leaking line somewhere?
Thanks <(''<)
Thanks <(''<)
if there's a lack of fluid, and you're not taking any out.. you have a leak!
Is it in the front or rear portion of the MC?
I believe the front portion is the rear brakes, and the rear portion is for the front brakes.
Which one appears low?
Not sure if a leak would stop the ebrake from working or not.. someone else can chime in on that. That's probably your problem, though, or you just need to adjust the ebrake
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
One of your brake cylinders is leaking in the rear.
Also rear brakes do not self adjust well. They need a manual adjust every 6month to keep the Ebrake working well.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Originally posted by Apeiron
No, the ebrake is purely a mechanical system.
My e-brake doesn't work but that's because I don't have the cables hooked up anymore. Haven't decided how I'm going to get these parking brake levers to match up to my cable. Oh that, and I removed the parking brake drums because I thought they were the cause of a noise I had..turns out I need a new caliper (which should be here tomorrow! )
It's a mechanical system but beleive me, if one of your rear brake cylinders is leaking (drum brakes) the e-brake isn't gonna do much for you. The brake fluid gets on the brake shoes/drum and reduces the friction coefficient to, oh, about the same as wet ice sliding across teflon.
If it's rear discs then the self-adjusters on most (all?) years of the 3rd gen were problematic. Not that it was entirely the adjuster's fault- often the e-brake cables got sticky and wouldn't return fully, allowing the calipers to self-adjust.
Engine: 383 Carb
Transmission: 4L60
People like to forget that brakes have to be regularly cleaned, lubed and serviced just like every other system on the car.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
