Somebody get me a doctor!!!!!!!!
#51
Our firebird fuel line was too close to exhaust,, vapor lock,, on your car, could be same thing... or wrong/weak valve springs
Also, we had a truck that was doing something similar,, had a cheap pump on it,, the pump motor would get hot and would not turn fast enough, truck would run fine after it cooled down,,
fuel starvation to the pump will cause it to get hot and turn slow also,, like maybe the inlet is stopping up,, also if the tank vent is stopped up it will pull a vacuum and not get fuel, and or the gas tank cap vent,, about as long as it takes the car to warm up is about as long as it would take for it to pull a vacuum and quit pulling enough fuel to run fast.... our firebird does this if the vent is plugged
#52
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Could there be loose particules of rust in the tank that are all collecting on the sock/pre filter starving the pump for fuel, thus dropping the pressure?
that would explain why it has pressure cold right? and why it disappears after ten minutes.....:shrug:
#53
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally posted by smithtc
...also if the tank vent is stopped up it will pull a vacuum and not get fuel, and or the gas tank cap vent...
That would qualify as an overlooked something. Easy test is keep the bloody gas cap off while running the engine to the point where you typically run into problems.
One other thing, is it possible to get some pics of your vacuum routing on the pass side.
#54
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I agree with SmithTC. Check for the fuel line to close to the exhaust. Also the vent for the fuel tank. I have seen both happen. Allen
#55
Originally posted by RMC030
Holy Crap! Gentlemen (and I use the term loosely) Can wee please remember who is having a problem here! I know it not all about me (well this is) but kicking each other in the nuts over who says what and to who is not going to help me look for answers! I am open to suggestions and if someone does not do their homework and read the whole post then I will still entertain their reply.
Now back to the issue at hand. If anyone knows of someone in the Northern New Jersey, or close area to, that can datalog my vehicle please let me know. If it was not such a pain in the ***** to drop the tank, I would have bought another pump and installed it already. Money, at this point is not an option. I've dumped far more money into the vehicle to get to this point, I'm sure a few more bills is not going to matter. Thankfully it is not my daily driver.
im going to tell you a short story
guy has 1990 mustang.
shop puts in a fuel pump. car craps out
another shop puts in a fuel pump. car craps out.
another shop puts an intertia switch in
geuss what car craps out.
next shop replace the the fuel pump relay and the EFI relay and rewires the whole damn thing from the tank to the back of the car geuss what. car craps out.
now how did i find this ??
USE A LOW AMPS PROBE !!!!!! your fuel pump actuall draws the largest amount of current at idle. thats becuase its working super hard having to bypass directly from the regulator to the tank.the largest amount of fuel goes back to the tank KOEI KOEO
so if the pump has a good electrical pattern at idle with the relay jumped and the engine off i can guarntee you its not a pump. also pinch the return line off see if the pump craps out electrically at higher fluid pressures. fuel pressure does go up around 5-6 psi at WOT. vs engine idling
now with that said.
are you using the correct sock on the pump ???? cavitation can cuase similar problems
check the actuall potted wiring going into the tank sneding unit. i have seen ( the above mustang) high current high vloume pumps will load the wiring up and the potting will break loose the wiring will break and the sending unit was the real culprit.
but since its a problem you only have at 1/2 to WOT. id think you most liekly have a restricted fuel filter or something. sounds like a pinched line etc etc etc. if you dont have volume then you cant have pressure.
an electrically bad pump would have striaght up quite working. aso i hate to say this but have you checked the connectors comming out of the rear sheet metal ??? i know it is a pita to remove but you may want to yank the rear seat pull up the carpet and inspect that connector inside and out. at least that part can be done without droppping the tank.
id still check for a pinched fuel line. espcially if someone has put you car on a hoist right before the problem started. youd be surprised how many pinched fuel lines ive seen in my life due to negligent lifting.
#56
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i know you said you changed it, but something else to check is the fuel filter, i have seen more than one GM vehicle where the filter got put on backwards & was missed by more than 1 shop. put on the wrong way they would work fine, for a time & then start working like a check valve & cause problems like what you are describing.
the only one i cut apart the filter media had collapsed in it. it was designed so when installed in the right direction the fuel flowed in into the center of the media to the outside of it.
i think what happens when the filter is on backwards is when you are on the gas harder the flow increases through the filter which is what collapses the media which causes reduced flow, the more it collapses the more the flow is reduced which causes it to collapse even more. turn the car off for a few minutes & the filter returns to a somewhat normal shape & will allow fuel to flow normaly through it again. the longer the car is off, the longer it takes for the problem to come back.
what funstick said about using an amp probe would show this as an increased current draw.
#57
Engine: LT1, L98
Transmission: ZF6, ZF6
Axle/Gears: 3.45, 3.31
Originally posted by Red Devil
Did you swap out the maf and fuel relays? I still think you ought to datalog the car. We're into guesses now.
*the ECM completely
*the relay
*the oil presure switch
If he is loosing presure with 12.0+ volts, then he either has
*a bad pump,
*a restriction (Sock, filter, kinked line, etc)
*a leak (the hose between the pump and the sending unit?)
I think the fuel filter (backwards) and the tank vacuum are both good suugestions and definitely worth checking.
#58
Car: Tree Huggers
Engine: Do Not
Tom, why pick one of my older posts in the thread to quote? It really wasn't needed for what you posted, however, it does illustrate a good point here in that I still am unsure if the pressure drop corrolates exactly to the switch to closed loop.
You could also have easily just suggested putting 12v to the G terminal of the aldl immediately after a stall to see if the static pressure goes past 10 psi. I still don't see how my earlier post puts your into context or anything. :shrug:
#60
Engine: LT1, L98
Putting 12v to the ALDL tells the ECM to engage the fuel pump relay doesn't it? I would suggest by-passing the relay first w/a jumper wire, to verify that the fuel pump and lines etc. -the basic parts- are working correctly.
#61
Car: '88 Formula, '95 Formula
Engine: LC9 , LT1
Transmission: TKX , 4L60E
Axle/Gears: 3.50 9" , 3.23 10bolt
(1) What was the problem then with your buddies LT1? How was it corrected?
(2)At the top of this thread I listed all (I mean ALL) of the things that I did to the car. What it started out as, and what I did during the swap over.
(3)I'm a pretty meticulous type of person. That being said I made 100% sure anything I did during the build, and after would not be an issue. Granted it is not a Top Fuel Dragster, but I wanted it to perform well and still be reliable.
(4)The common denominator in this whole problem is ---
X + warm temp = fuel pressure drop
So we (I say that collectively) need to find out what (X) is!
I now know what (X) is not, and I am running out of options.
(5) My car is like the town hooker! It's been to almost every shop in town, but still leaves everyone scratching their heads.
Do you have a fuel pressure gauge on the car right now? If not, can you please install one that you can see from the drivers seat? I"m willing to help you solve this, including you coming into thirdgen chat and me walking you through this. But you need to follow what I say exactly, since the car is not infront of me.
First thing i'd like, is for you to have both a fuel pressure gauge, and your scanner connected to the vehicle.
When the car enters closed loop, i'd like you to record the blm and int at idle. How quickly the o2 crosses, and a rough idea of the o2mv, and note your
fuel pressure.
Start driving.. Do what you do to make the car "break down". While its breaking up or down orwhatever you call it, have a co-pilot record the fuel pressure, blm, int, o2mv, spark advance, and knock retard.
Come back to me with this information.
This is the first thing you should have done. Log engine data, and record fuel pressure.
-- Joe
#62
Car: 1988 Pontiac Trans Am
Engine: 5.7 Tuned Port Injection
Transmission: Borg Warner T-5 5 speed
Here are the numbers I sent to Ed Wright when I thought it was the chip that was causing the problem.
RPM-- 1900 3200 4000
Block Learn-- 122 128 128
O2-- 51 23 4
TPS-- 1.32 2.96 4.32
Temp-- 173 173 175
MAF-- 47 131 168
I have since changed the MAF and TPS, but the numbers should still be similar due to the problem. When You baby the throttle, it maintains enough fuel pressure to drive. I had it out on Christmas Eve and it stalled twice on my way to a party. When I left two hours later, I was able to leave two long strips on the main road. When I made the turn onto my street, it stalled and again in the driveway.
O2-- 51 23 4
Temp-- 173 173 175
MAF-- 47 131 168
#63
I took my headache to another shop. The owner looked at my car an spent some time on it. It all boils down to a bad fuel pressure regulator and one bad injector. So I rodered the TPIS regulator and will exchange the injectors for another set. I should have parts by Monday and hopefully have the car back on Wed. or Thurs.
hookin88formula
05-02-2001 10:56 AM
