quick question about carb cleaner
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
Can you just spray carb cleaner in your intake and not have to worry about anything (305 TPI). Or do you have to pull off the plenum and then make sure that it is dry when you put it back on.
I pulled the plenum once and I did not get to clean all of the carbon off before I put it on.
Thanks,
Jesse
Thanks,
Jesse
oldblue.. as far as i know you can spray the carb cleaner directly down the throat with the engine running...the carb cleaner is combustible so it will basically dissolve the deposits and reburn them cleaning your Plenum... There is a product from 3M called Throttle Plate Cleaner that comes in a trigger aerosol can with an extension tube to get right in... Just open the throttle plate and spray it in to clean it up nice and good..
Mike
Mike
88 Iroc-Z 350 tpi, Hedmann Headers, 3.5 " Cat Back, MSD Ignition, K&N Cold Air kit
Mike
Mike
86IROC112
08-17-2015 02:00 PM
