Running in 4 cylinders!!!
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Hello, my 305 TPI is runing with only 2,4,6,8 cylinders working, the whole driver's side is not working. I do have ignition in the spark plugs but it runs very rough and when I unplug the injectors on that side, nothing happens for better or worse. When I unplup the spark plug wires one by one, there is spark but no change either. Is there some kind of "shared ground" on those 4 injectors? I have no SES light on or codes advisory. It's been parked but I start it once a week or so. I didn't start it for a couple of weeks 'cause of the hurricanes here in FL but it didn't get damaged by water or anything like that. A couple of days ago I started it and it worked fine, the whole 8 cylinders were working fine but it started to act up again. I started it a couple of hours ago and it is still in 4 cylinders. Please help me! Sorry for the long letter.
Thanks, David
Thanks, David
Car: 91 camaro rs
Engine: 350tpi
I would guess that one of the drivers for your injectors is bad. Go get a noid light and hook it up to a connector to verify it. Otherwise you could just replace the computer.
Thank you so much. It's fixed now!!! I checked the fuses, as a couple of guys told me in the TPI forum and they were both fine. I actually interchanged them and same thing. I took the #1 spark plug and it seemed fine. So I started thinking about the computer, as one of the guys mentioned. So I tapped under the dash where the computer is located and it worked perfectly fine. I am guessing that moisture probably got a hold of the computer connections, but it's working fine now. I'll take the covers off one of these days and check and clean all connections there. Thanks again!
David
David
NinjaNife
08-23-2015 11:49 AM
