Cruise Control Help
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Cruise Control Help
I'm looking for a little help on diagnosing a cruise control. It doesn't work :-) I have vaccum to the diaphram and signal from my interior controls. I checked for power as well, so no burnt fuses or bad wiring. This means, correct me if I'm wrong, that the two electronic boxes behind the dash must be the culprit. Has anybody been here before? Can parts store diagnose the boxes if I pull them? How easy are they to get to...ie what else is going to have to come off to get to them? Thanks for the help -Jerod
Mint black/black 1987 T/A GTA 305 5-speed, 55K,
3.45 factory POSI,SLP cam, SLP runners, Taylor wires, hurst comp plus shifter, K&N conical rig, AFPR, coated shorty headers, no cat, no smog, 3in. mandrel-bent single exhaust, flowmaster, TB air foil, 160 stat, SFC's, lower control arm adapters, Aluminum Driveshaft, ported upper and lower, Mobile ES and 10 disc, kickers all around and q-logic kick panels...Perf 350, rear batt, lowering springs,cowl hood, & NOS coming soon!
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Not trying to bash on you....but did you check the c/c linkage at the throttle assembly?
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Performance:
Electronics:
wigmobile
09-17-2015 03:38 PM
