Crank, no start problem. Anyone?
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
1989 Camaro 5.7 Tpi, auto mass-air engine. O.K. here goes I have a crank no start problem and have followed the G.M. service manuals flow chart and have come up empty and I'm wondering if anyone has run across something like this.
Mods : afpr, ported plenum, slp runners, accell fuel injectors, slp headers to 3" flomaster, missing egr, missing air mgmt., crane hi-6 cd box, hypertech chip, pulleys, new msd cap and rotor, accel 300+ race wires, air foil.
It has plenty of fuel pressure, it has a bright blue spark, noid light blinks on both fuel injector harnesses, scanner reads rpm when cranking.
The S*** of it is this thing will run reliably if you shoot choke cleaner in the plenum before trying to start it. cold takes a one second blast, hot takes a quarter second blast. If I dont forget to bring my can of cleaner I can get it to start every time but without cleaner its the nike express.
If anyone has experienced this let me know!?!?
Iroc Z28 with several mods for domination of autocross courses.
no codes? have you checked the cold start injector (if 89 has one)? after the cold start injector i'd be looking at the tps and cts.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
No cold start injector, no codes, throttle pos sen is set at .56 with scanner. cts is reading correctly. Would a leaking fuel injector cause a no-start situation? pressure not holding when feed and or return line is crimped which means leaking inj, right.
1 Post
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Mine would do this when hot. Turns out one of the injectors was going to ground when hot. Since all injectors share a common ground -and- electricity follows the path of least resistance, the one bad injector was stealing voltage from the others not allowing it to start. With a shot of starter fluid it would fire right up. The noid light lit up but was rather weak.
I had great fuel pressure and everything else was replaced or swapped, i.e. coil, distributor, ECM, chip, Ignition module, IAC etc. Took me a month to figure it out then I had to take it to GM Tech to figure it out.
Hope this helps.
Oh, 92 MAP system.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Hope this helps.
Oh, 92 MAP system.
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
I'll have to check the injectors a little closer. I ohm checked them before installing them, they seemed all good, mabye one went south. Thanks for your input.
92camaroJoe
08-13-2015 06:07 AM
