Gas Milage, before OD and after!!!
Car: 99 Formula
Axle/Gears: 342
When I bought my car it didn't have OD, and I always got around 14 mpg, now I just got my tranny rebuilt and after calculating for the first time I am getting about 16mpg, does this seem to be right, I was hoping for around 18mpg.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Rebuilt 700R4, with manual valve body
coming soon B&M Quicksilver Ratchet Shifter
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
2:73 GEARS
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Depends on the type of driving. If it's stop and go city driving, thats probably correct. If you're looking at mostly freeway then you're mpg should have gone up a little more I'd think.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
Car: 82 camaro SC
With 2.73 gears, you won't gain much mileage because 2.73's without overdrive isn't that bad of a combination. If you had 3.73's, your mileage increase would be larger(3.73's without overdrive will get you 3000rpm at 60mph). Gear ratio can only help so much. If you swapped in 3.08's or 3.23, you would get about the same mileage with overdrive.
...I can get 20mpg w/3.73's and overdrive if I'm really nice.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
[This message has been edited by 82camaro (edited May 22, 2001).]
82camaro
tonys91rs
10-10-2015 03:31 PM
