Up to what HP can the puny 48mm throttle bodie on TPI's hold.
I had my stock 48mm throttle bodie ported to 52mm, and before i even started the motor, i sold it to this guy who wanted it bad, for $200.00 plus his stock 48mm throttle bodie. As u can see, the 305 isnt stock, so my question is can i use the stock 48mm throttle bodie on the modded 305 TPI or should i go with a 52mm. I thought about sending it to TPIS or getting a brand new aftermarket TB. How much HP can the 48mm throttle bodie support. Im guessing the motor should be making 300-330 hp at flywheel. ANy suggestions or ideas.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
92' camaro
Soon to come!!!
Other car;
That same 48mm TB is what they use on the 510HP Ram Jet 502. That should be enough for a 305.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Well, when you get that 12lbs of boost i would suggest the bigger throttle body. But as it is now, i would say the bigger throttle body's gains compared to the amount of money you'll have to spend wouldn't be worth the investment until you get boosted.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
Car: 04 GTO
Transmission: M12 T56
Without knowing your cam specs it's hrd to say, but you definitely won't see a big gain by swapping at this point no matter what. You have to decide if it's worth maybe a tenth or two for the money.
btw, might want to trim that sig, it's impossible to read. I went over it twice looking for mention of the cam, only to finally see the part about accel cam w/ no specs. At least cut out all the dumb **** like air foil, 19lb injectors (stock rating who cares what brand), timing chain (again, who cares what brand) wires/plugs/cap/rotor. You might have a pretty potent combo, but that sig makes you sound like the typical moron guy who thinks M1 and zaino are mods.
Maybe something like:
92 camaro , T5 , Zoom clutch
310c.i all forged for N2O , ported vette heads
Edel. Base, SLP runners, Comp RRs, accel cam (211/219, .500/.500)
Edel. headers, fromaster exhaust, and all the little stuff
in progress: N2O and the fuel system to match
That way you only list the stuff that people care about, and when you're looking for advice, we can figure out what you have without getting a headache.
...ed
ps. Didn't mean to single you out, i'm just bored killing my last few minutes at work, and instead of just saying your sig is hrad to read i figured i'd show you a better way.
...ed
Don't Forget to List the Tb Bypass Tho.
if properly bypassed, that 48mm throttle body can support plenty of airflow
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 15.26 @ 87.0
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
mdtoren
08-16-2015 05:45 PM
