Thread chasing set?
Thread chasing set?
I want to get a thread chasing set to clean up the threads on my 350 block. So I went to Summit and Jegs online and found what I want. However, summit offers one for coarse threaded holes and jegs offers two for coarse and fine. So which set(s) do I really need?? Coarse by itself or both? Does anyone know which holes on the block are coarse and which are fine? Sorry for the lame question but I don't want to ruin threads with the wrong tap.
The summit part # is SUM-900200
Th link to jegs: Jeg's kit
Thanks!!!
Thanks!!!
Save the money on a high dollar set of thread chasers.
Pick up a set of import tap and die set from Harbor Frieght, etc...should be about 10-15bucks for everything you'll ever use...I don't recommend tapping and threading with them (too easy to break) but they work great as chasers.
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Or you could just get the individual taps, it depends upon the job you intend to do though, I guess.
For engines I don't end up using anything but 7/16 coarse for the headbolt holes and 3/8 coarse for the intake exh and waterpump holes.
These sets are not expensive, we're talking 10-15 bucks. All I want to be able to do is clean the threads by running something through them. They do not need to be repaired or anything, just clean the junk out.
Streetiron - sounds like you use the coarse threaded for almost everything. Is that a tap or a chaser?
what does everyone else use? Just regular taps?
thanks.
thanks.
Car: '85 IROC
Engine: LB9
If you're talking about cleaning threads in the block, coarse threads are all there is.
I just use a tap.
For myself it's never been nessecary to clean threads anywhere except the intake, exhaust, headbolts and waterpump.
If you have some other uses in mind then maybe a set is a good idea, but for block and heads 2 sizes are all you'll need.
I just use a tap.
Street Lethal
04-30-2019 12:14 PM
