4-port Canister control valve, CCC car; lots 'o q's
Car: 84 T/A
Engine: 305HOL69
My car hasn't had this on it probably for awhile now, but I got one from a boneyard just incase. Question is, other than emissions, does the car need this to run good, or is it beneficial to performance? Better or worse for fuel mileage?
Without this valve, my canister has always been hosed straight from the canister outlet to the bowl inlet. My tank pres valve has always been hooked up to the "H" vac port at the right, below the TPS connector. PCV is run straight to the carb base.
Car runs great, except it doesn't like to start up cold. When started warm it'll get a sloppy idle and recover after about 30 sec-1 min. Would this be because that valve is not there?
DR Stevens
1984 Trans Am 305HO L69
1991 Firebird 305 L03
[This message has been edited by eightTfourTA (edited May 19, 2001).]
DR Stevens
Ghettobird52
07-05-2024 11:18 PM
1992 Trans Am
05-10-2023 07:19 PM
1992rs/ss
05-19-2020 07:02 PM
mustangman65_79
08-11-2015 03:17 PM
1992 Trans Am
08-08-2015 08:16 PM
