Can you reuse wet sparkplugs?
Car: Death Mobile
Engine: 666 c.i.
Originally posted by DANIELEK
No, my entire car fell into the lake..
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
There have been a few questionable posts recently, most notably, the aluminum runners getting imploded by manifold vacuum, courtesy of TravisZ.
Car: Red Rooster
Transmission: M5
Originally posted by Glenn91L98GTA
The entire car fell into the lake and you are worried about the spark plugs? I'd be worried about other things.
But i ended up getting a new one from GM (thanks *** for insurance)..
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
New engine SHOULD = New plugs. Just my opinion!
New engine because of digesting water? Pulling the plugs to dry out the cylinders, and changing the oil will usually get it back going. I've seen a few hydo-lock from fuel (bad injector, pressure regulator, etc...) and they usually survive.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If its already hydrolocked though, then they rods are bent. No saving that motor. Block maybe, and maybe some of the top end, but its still gotta come out.
Car: Red Rooster
Transmission: M5
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Originally posted by Stekman
This is one of those times where I THINK he's joking, but I'm not certain....
well he is candanadian (don't ask) and you know their sense of humor....
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
WhteRbt
09-21-2015 09:48 AM
