Anyone else have an annoying buzzing noise????
After my slow a$$ LG4 has been warmed up, I start hearing a buzzing noise. It makes my car sound like an 88 Camry. My dad said it was the air pump. Any other ideas? Thanks.
Car: 99 Formula
Axle/Gears: 342
Is the buzzing coming from under the dash, if so, that is your relay module, it buzzes when ever the battery isn't charging the way it should, is your voltage meter reading low.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
Car: 2002 SOM z28
Or else when you've grounded the positive wire to the choke onto the intake manifold and blown the 20amp fuse... I have a box of them in my console just for that reason
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Does the noise occur only at idle, or at all speeds?
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Later,
Vader
"What a Day..."
Does it sound like it might be from the transmission?
Later,
Vader
"What a Day..."
Later,
Vader
"What a Day..."
I get the buzz from the tranny sometimes...I've been told its some sort of pressure oscillating valve...any truth to this?
1991 Firebird Formula
305 TPI,Auto,Custom 3" Mandrel bent I-pipe, Flowmaster 80 series muffler, 3" hi-flo cat, Accel Cap & Rotor,Taylor Spiro Wires,Bosch Platinum Plugs, K&N Filter, Grant GT Steering Wheel, 5% Rear tint, Pontiac Windshield Decal, Fresh paint
Former owner of an 88 2.8 Firebird....RIP
The Problem is your fans tighten them down there knocking against a metel piece from your ac or your radiator
1987 IROC-Z
G92, LB9 305 TPI, 3.23, Bright Red with Carmine Interior, Pioneer DEHP47DH CD deck.2 JBL DS645 4*6 (F).. 2 JBL DS965 6*9 (S).. Soon to be 335 or 350 TPI...
1987 IROC-Z
sjorgens
10-01-2015 07:54 PM
