Weiand Intake ?'s
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Weiand Intake ?'s
Do anybody know anything about the Weiand 7502 intake manifold. It is a DP with exhaust crossover. The port measure 1.13X1.93". It looks like a stock replacement to me, what do you think?
Car: 82 Z28
Transmission: TH350
The intake looks almost like an exact carbon copy of the Weiand Stealth 8016 the runners externally look to be the same. There are the mixture turbulence ridges throughout the entire intake plenum.
Car: 82 Z28
Transmission: TH350
The intake also has a carb pad height of about 4.15" and 4.5
". So about the same as the Stealth.
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Looks like a stealth.
I am running the stealth on my 355 and so far I haven't been able to take it out and try it on the street. I chose it because of the bigger runners than the Action+, and thier claim of an rpm band to 6800rpm, and I needed a low intake for hood clearence.
Car: 82 Z28
Transmission: TH350
I think i'm going to run it. I'd say that it is an early Stealth design or pre-stealth design. Does anybody know the size of the stock 416 ports? I want to decide if i should port or gasket match the intake.
toronto formula
09-10-2015 07:31 AM
e3pres
09-09-2015 01:51 PM
