Who has stroked a 305?
I know there are people out there who have done this and I just want to know how much horsepower and torque you got from stock? Did you feel the difference after the conversion?
Robert
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
I like to think of her as Arnold Schwartzeneger in a dinner suit
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat. K&Ns, AFPR and Air foil.
Future mods:
Cam change
New torque converter
New heads (maybe corvette L98)
Strut brace
Sub frame connectors
Ram Air
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph
Robert
Mods
Future mods:
Cam change
Strut brace
Ram Air
1/4 14.74@100.2mph
I can tell you in about 2 weeks. I'm just finishing my 335 stroker project. Is an '84 L69, 335 stoker, S/R Torquer heads, 262XE cam, roller rockers, Edelbrock intake, Edelbrock TES headers.. I'll post specs when I get back from the dyno... I'm guessing 325-350hp range from other similar builds I've seen..
1 Post
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
You will definitely feel the difference. Gains are realized in both rod size and strength and are almost instantaneous.
1 Post
Car: '92 Camaro RS
Engine: 350 H.O.
Axle/Gears: 3.73 posi
Either Super Chevy or Chevy Hi-Perf did a full article on stroking a 305 to a 335 a few months ago...I think they installed it in a Camaro they gave away. I'll flip through some past issues and give some more specifics...
1992 Camaro RS
305 TBI, 5-Speed
K & N open element, Hooker cat-back exhaust,
SplitFire plugs, Moroso Blue Max wires,
Macewen white-face gauge overlays,
Hypertech Power Coil Kit
http://www13.brinkster.com/scbaeb/camaro.html
scbaeb@hotmail.com
1992 Camaro RS
305 TBI, 5-Speed
scbaeb@hotmail.com
Bulldog92
I'll look forward to that article, thanks.
Yes, I had expected the stroking jokes.
Thanks again
Robert
Thanks again
Robert
I have that isssue right infront of me!!! I never miss much when it has a camaro on it. I was all excited to do it but I found that it was going to be quite expensive. You are dealing with a new crank, new rods, new pistons because the rod mounting is different because of the stroke. You could build a 350 cheaper. I would still rather have a stoked 305 though. It would be awesome to smoke 5.0's with a stock looking motor."Yup it is really just a 305 that whooped you " HHAHAH
I would like to hear more about doing this though!!
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit 3.42 rearend
One sweet sounding system
91 Z28 Camaro
305 TPI
Purpleworm, I agree with your sentiment about sleepers. However, unless someone gets down close enough to look at freeze plugs, etc... they won't know a 305 from a 400.
'93 2wd truck
408 sb, vortecs, 454 TBI, Comp Cam, dual exhaust
'93 2wd truck
It is just the fact that you would be beating on mustangs with the 305. The stroked 305 would give you even more torque and less top tho, right? I guess it further complements the TPI setup
Car: 1984 Z28
Engine: Custom built 383
Transmission: Tremec 3550
<font face="Verdana, Arial" size="2">Originally posted by purpleworm:
</font>
</font>
'84 Z28 w/ T-tops, 420HP Stroked 383, Trick Flow aluminum heads, Tremec 5 speed, 3.73 posi rear, Edelbrock 750 cfm carb, Dual Snorkel air cleaner w/ K&N filter, Edelbrock headers & 3" exhaust, Edelbrock Strut Tower Brace, Hotchkis LCA's and Panhard Rod, there is much suspension work to come.
1979 Corvette - Black/Black - 350 CI L82 w/ MM4 close ratio 4 speed manual
"Smoke 'em if you got 'em"
Stroking a 305 takes what is already bad about a 305, its stroke is too long for its bore, and makes it even worse. If you want to stroke an engine, stroke a 350 to make it a 383. If you want to be an underdog with "something different" go right ahead. I'll take a 350 or larger any day.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
