275/50/15 tires on 15x7 Firebird rims for racing?
Wondering if these tires are too wide for drag racing on a 15x7 rim. They say they will fit rim width of 7-10 inches. I don't think the next size smaller 235/60/15 will have enough contact for a mid 13 second car. These are BF Goodrich Drag Radials going on standard 15x7 inch Firebird rims
Founder of the Greater Cincinnati F-Body Association
1988 Yellow Trans Am GTA
Click here for photos
The widest I could go was 255 on my stock 15" rims without rubbing.
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit 3.42 rearend
One sweet sounding system
91 Z28 Camaro
305 TPI
Car: 04 GTO
Transmission: M12 T56
They'll work pretty well when aired downa bit, but if you run 'em on the street they'll wear out in the center pretty fast. I ran 265/50/15s on 15x7 rims and they definitely took more wear in the center even when inflated just right.
And i think more than few people have gone pretty fast on 235/60 radials, let alone drag raidals. I can't name specific people/cars, but if you'd rather have a tire that fits the rim and doens't look boy-racer you can run well under 2.0 60's on the 235s.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
...ed
I run 275-50-15s on my stock 15x7 rims. They don't rub, and work great. Thay are worn down much more in the center than on the edges tho...I dunno if you could fix that in the future by running less air pressure or not.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
JSP Motorsports
ICON Motorsports
Street Lethal
04-30-2019 12:14 PM
colton_carlson
03-08-2019 12:21 PM
