Wieand stealth or Edel airgap??
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
just wanted to get some opinions on these two manifolds. Would I see a noticeable gain from switching to an edel airgap? Thanks for any help
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
With your engine mods, I would suggest the air-gap...even more so if its gonna be a daily driver. You'll get better low end torque and overall better driveability, anything besides advantages I mentioned is not worth it for a true daily driver.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I don't know but i'm swapping from as stock 346250 Iron Q-jet intake to a Weiand Stealth. I have a 1" carb spacer/carb adapter under my Holley 600. Getting rid of the adapter alone will probably add some power, due to the better flow characteristics.
I will let you know how it goes!
L98GTA87
08-11-2015 06:55 PM
