Dent in Oil Pan- Crankshaft Hitting
Car: 1989 Firebird Formula
Engine: Chevy TPI 350
Transmission: A/T 700 R4
I have a large dent in my oil pan, and while the car is crunk the crankshaft is hitting the pan as it turn. What is the worst that could happen if I keep cranking it like this? Also, what is the best way for me to change an oil pan?
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: Dent in Oil Pan- Crankshaft Hitting
changing the oil pan will require you lifting the engine high enough to get the pan off and slid out over the crossmember or pulling the engine out its not the easiest job to do.
but do it .
Car: 4
Engine: 6
Transmission: 5
The worst that could happen is that the crank could wear a hole in the pan and the oil would then fall out.
The best way to change the pan is to remove the old one, and install a new one.
You can often use a slide-hammer type of dent puller to pull a dent out; and then braze the hole over.
you dont think that wearing a hole in the pan will put shavings in the oil?..
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
as it pulls it thru the oil pump i guess it wont hurt anything either??
1 Post
Car: 1984 Camaro Z28 HO
Engine: L69
That's the easiest way if you don't have a engine hoist handy.
Car: 91 maro
Axle/Gears: 373 locker
thats wrong cause a stock motor has a byepass in the filter housing cause it doesent flow fast enough unless u bought a kit to fix this wich u wouldnt be able to run just any ordinare oil filter it will get in the oil system and ruin the bearings.i would just take motor out and get new pan its cheep like 20-50$ i bet ebay sells them cheep
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
This thread is over 3 years old, but that's not how the bypass works.
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
jeebus! i always end up reading the whole thing before i realize it... 2004 huh seems like only yesterday
Hotrodboba400
12-10-2019 07:07 PM
