P/S Pulley Install
Car: check
Engine: check
Transmission: check
P/S Pulley Install
What is the thread dimension for the inside of the P/S pump pully shaft? This is the thread used for the installation of the pulley. IOW, thread a stud into the P/S shaft to push/press the pulley on.
In particular this is for an '85 LG4 Camaro.
These threads get rusty and I can't tell what size they are. Need to run a tap down it in order to get a stud in there. Of course need to get a threaded stud of the correct dimension too.
Thanks,
RBob.
Thanks,
RBob.
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
It is definately 3/8 x 16 NC thread.
Go to Auto Zone and rent their PS pulley puller/installer. It has an installation tool with a bearing on it and makes putting the pulley on a real breeze. You just pay a deposit for the tool, then get it all back when you return it.
evilstuie
01-09-2020 08:29 PM
evilstuie
04-14-2016 08:52 PM
Navy8125
08-22-2015 07:13 PM
mcquigg
08-13-2015 02:26 PM
Street Lethal
08-12-2015 11:33 AM
