Cam Suggestions???
Cam Suggestions???
I am looking to put a new cam into my LG4, but can't come to decision on which one to get. I am looking for a good amount of low-end torque, and a mild idle. I am going to put a dual exhaust system on my car, and I have a new Weiand stealth intake to put on once I get the cam in. I am looking at Competition Cams and Lunati right now, but I am willing to look at anything.
lunati pn 00017 .460 and 224*@.050
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 2006 Silverado 1500
Engine: 5.3L
i'd say a good choice would be comp cam's no. 12-231-2. it has a 111 lobe separation with 206 and 214 at .050 duration. lift is .432 and .453 lift with 1.5 ratio rockers.
Zippy's suggestion is a good one. That or one close to it (there are dozens) would do you well.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
JSP Motorsports
ICON Motorsports
224* of duration for an LG4????? That would be just a bit extreme, even for some L98s. I agree with the suggestion Zippy made. If you want some more upper RPM power you can look into some 1.6 rockers for that cam, at least on the exhaust side.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
L98 TPI 350 (5.7L)
<font face="Verdana, Arial" size="2">Originally posted by JACZ28:
What do you guys think about lunati cam 00016 it is a single-pattern cam with 218* @.050" .458 lift and 110 lobe seperation. </font>
Heres one that I think looks better than the "comp magnum 224@.50 <-- all my cars and my truck have this cam and I recomend it "305, 350, 355" But heres the numbers off a melling that this guy told me about and it looks better than the comp and you can get it at autozone.
Melling performance "22210"
114 lobe int @ exh
c lift .300, .307
valve lift .450 .461
sae-291int 287 exh
224@.50
SSC
junkcltr
08-02-2019 11:12 PM
