I'm cranky.....
Car: 1987 Z28 Convertible
Transmission: 5-speed
I'm cranky.....
.... because I can't find a small block Chevy crankshaft with the following specs:
4340 Forging
Stock stroke (3.48")
One-piece rear main seal
Anyone but Scat (extremely bad experience so no more of these for me.)
I thought this would be easy. It turns out that all the cranks I've found that are 4340 steel have a two-piece rear main seal. The only one-piece rear main seal cranks are strokers (3.75").
Does anyone know of such a crank?
Willie
4340 Forging
Willie
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Something like this:
http://www.cnc-motorsports.com/produ...471&CtgID=8469
Or are you thinking more high end? Crower? Callies? Cola? Lunati?
Thanks. I forgot about Eagle. I believe they are "equivalent" to Scat. I'm looking more for a high-end crank. Here's what I know to date:
Crower?
I've left multiple voicemails and have not received a call back.
Callies?
They do not make it. Confirmed via phone. Of course they could fab one to the tune of $2000.
Cola?
I've heard good things about Cola. I'll have to search to find a distributor to ask questions... Thanks!
Lunati?
I've heard they don't make one either but have no confirmation.
Willie
Crower?
Callies?
Cola?
Lunati?
Willie
Car: Z28
Engine: Sb2.2 406
You can always run an rear main seal adapter. (1 pc RMS block, 2 pc RMS crank)
Cola looks promising:
http://www.racenet.net/eng/cola-cranks.php
They don't post their prices, so..... you know what that typically means.... I'll have to call in the morning. Thanks again!
Willie
Willie
Car: Z28
Engine: Sb2.2 406
Alright, I did some digging for you, Willie.
Lunati crank (not sure about the material, I believe it is 4340, though), make sure you see the note at the bottom of their page.
http://www.holley.com/HiOctn/ProdLin...CS/RaceSB.html
And for your viewing pleasure, here you are, Willie, Titan-Cola crankshafts (you can call them if you want to verify anything):
http://www.titancranks.com/
Looking at the real top end guys (Childs & Albert, HTC, Sonny's), they don't list the rear seal, so, I don't think it's that uncommon for top enders to list the RMS.
Was there a pun intended in your title?
Car: 4
Engine: 6
Transmission: 5
Just call Cola and ask. 818-547-3600 Although it looks like they definitely do. http://cgi.ebay.com/ebaymotors/ws/eB...916980495&rd=1
Or Lunati; 901-365-0950
I've had good results with e-mail contact with Crower, Brian Crower usually is the one who answers back.
I appreciate the effort guys. Here's what I've found.
Lunati does not make one with a two-piece rear. It's too early to call Cola. But I did call Race Engineering (Florida), a contact I got from Lunati. They told me Cola is no longer is business!! They advertise a two-year guarantee but what good is it if they're no longer around? I'll still try calling after they open.
Any opinions on a forged 1053 crank from GM Performance? They ARE a one-piece rear main design.
Willie
Willie
Car: 4
Engine: 6
Transmission: 5
Cola no longer in busines??? That's funny; I talked to them on the phone about a week ago about a somewhat less run-of-the-mill requirement than yours, and they seemed more or less a going concern at the time. But I could have been hallucinating I guess, wouldn't be the first time; remind me to watch how much coffee I drink before I go calling people. Which one do you really need?
Last I knew, the GMPP HT383 crank was made by Cola. Maybe it was just more of me on drugs though.
At least I was told that Cola is no longer in business. I will attempt to call them later this morning.
I need a one-piece rear, found on the newer (1986? - ) small blocks. Apparently, everyone likes to stroke these when replacing the crank -- more power for no more $$$. I'm looking for a stock stroke, 3.480", not 3.750" with a one-piece. Basically, this is a replacement for the stock piece, only in a 4340 forging.
Willie
Willie
Car: 4
Engine: 6
Transmission: 5
Cola is listing one on that eBay auction right now exactly like you are asking, except it's for 3.500" stroke instead of 3.48"; that would add .010" to the rotating assy height, which would take out that much deck clearance, if you can tolerate the extra cubic inch.
Okay, I just talked to Cola. Alive and well. So I was given misinformation. I guess this happens occasionally. In fact, they had the crank I am looking for. It's been ordered!
I checked out the one on e-bay. Looks good but with my bad experience with a prior Scat crank, I felt I had no choice but to order a new piece from the manufacturer, for documentation if anything. Thanks again guys.
Willie
Willie
Rebuilding. I was lucky. The crank snout snapped at idle. Bent most of the valves and pushrods and messed up the timing gear. That's about it.
Willie
Willie
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
Willie
Willie
when u got some time Shoot over to camaroz28.com....there are more then a few blower cars on that site and the crank snout snapping not "common" but its well known over there....
Was it loud lol
