will not stay running and billows white smoke
Car: '89 Iroc
Engine: 305 tpi
Transmission: 5 speed
My ’89 TPI IROC has this problem where it stumbles and dies out when you take your foot of the throttle. It will crank and start up every time, but dies right after. You have to rev the engine to keep it running. Plus upon start up and after a prolonged idle it billows white smoke. Its been doing it for the past year
(the smoke has gotten really bad lately) and a half that I’ve had it and in that time I’ve replaced the following: MAF, fuel filter, cap, rotor, wires, plugs, battery, battery terminals, alternator, serpentine belt.
1 Post
Car: '86 Berlinetta
sounds kinda like two seperate problems between your stumbling and dieing, and the white smoke. Could be connected if a busted head gasket i supposed.... white smoke typically means there's antifreeze or water, being combust w/ the gas. Feel free to fill me in if I'm wrong here anyone.
- 89_IROC
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you said it's been doing this for over a year, have you been driving it like this?
what does the smoke smell like?
by chance have you pulled the vacuum hose on the fuel pressure regulator?
Car: '89 Iroc
Engine: 305 tpi
DENN_SHAH,
I have been driving it the whole time, but the smoke has not been “billowing” until this last week. To the best of my knowledge the smoke smells like normal exhaust fumes with a little burning oil. I have not pulled the vacuum hose.
Both the oil and coolant look fine there is no sign of cross contamination.
Originally posted by 1ftNGrave
DENN_SHAH,
DENN_SHAH,
- 89_IROC
