Weird gas gauge
Weird gas gauge
Hi guys, my gas gauge seems to be fluctuating all over the place. If I go up a hill it will slowly decrease and when I go down a hill it will slowly move up towards full on the gauge. Even if I drive on a flat road it will still not read correctly(sometimes it stays in the correct position then after a while it tends to wander..
Still doesn`t seem right it never used to due this before. my tank was at a quarter yesterday and after a little while it climbed to 1/2 of a tank at stayed there for a while would not move(I was driving on a flat surface)
What gives???....could it be a loose connection???....maybe it is the contacts on the gauge cluster itself????....should I clean them?????
[This message has been edited by im (edited April 27, 2001).]
Car: 88 Firebird WS6
100% normal for a GM of our era. But it should not wander more than about 1/8 of a tank and will move toward empty under hard braking.....
Maybe the sender is bad or a possible intermittant short to ground...
Does it favor one direction? Maybe you drive like a maniac (I bet I could get mine to wander over 1/4 a tank if I tried)
[This message has been edited by JoelOl75 (edited April 27, 2001).]
Location: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I agree, those gas guages are far from accurate. After I had my fuel pump replaced, the needle will show about 1/8th of a tank but I will run out of gas.
The best way to judge it would be to fill it up, reset the trip odometer, and pay attention to when the needle starts to move from full. When it starts to get close to the 1/4 mark, fill it back up to figure out exactly how much gas was left in the tank.
1/4 tank on my guage means about 2-3 gallons of gas left.
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Performance:
Electronics:
Mine does the same thing. I would have a full tank for most of the day and then all of a sudden I would have 3/4 of a tank in a matter of seconds. It did it on my 84 and my 91. I just think the gauge setup suckz.
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit
One sweet sounding system
91 Z28 Camaro
305 TPI
Ghettobird52
07-05-2024 11:18 PM
