blowing heater blower fuse
just some info:i was blowing fuses for the heater blower. i changed the blower and ac controller (selector). Still didn't fix the problem. i looked at the resister and it was fine. So,back to the schematics. This time i went to the ac area of schematics and found that i needed to isolated the ac system from the heat system. i disconnected the a/c cycling switch (on the drier) and found both wires were grounded. this told me that somewhere between the ac contoller and the cycle switch on the drier was the problem. the connector (c102) was the culprit. wires were fused togther within the melted connector, (no visible melting from the outside). replaced connector. working fine now.
