mechanical fuel pump outlet fitting?
Old 08-04-2004 | 04:23 PM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
What exactly is the output of the stock mechanical fuel pump? Is it 3/8NPT or ???
Cheers,
Si.
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
5/16 Inverted Flare
Old 08-04-2004 | 04:28 PM
iroc-si's Avatar
Cheers,
Si.
Old 08-04-2004 | 06:42 PM
iroc-si's Avatar
Are you sure? Reason I ask is that 5/16 seems a bit small. I'm trying to connect it to -6AN braided hose. It is smaller than a 3/8NPT and bigger than the -6an.
Wondered if this was the right fitting :
http://store.summitracing.com/partde...t=AER-FCM2108&
or :
http://store.summitracing.com/partde...rt=AER-FCM2111
Si,
Old 08-04-2004 | 06:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Arg, 3/8, not 5/16, I must have been thinking of the transmission cooler lines. FCM2108 should be the one you want.
RazorN8
01-07-2022 12:44 PM
Infested
05-23-2018 12:56 AM
theshackle
03-05-2017 07:37 PM
R3500
08-17-2015 01:16 PM
