Bearing Grease In New Oil Pump??
1 Post
Car: 89 IROC-Z
Engine: 383
One of the mechanics I work with suggested that I pack my new oil pump with bearing grease to get it to pick up oil quicker upon initial startup. Does this sound right to anyone or will it clog my oil passages? I'm guessing it will clog my filter, but that gets changed after the first 20 minutes of running anyway right?
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Attention Everyone!!! I will be changing my name on the message boards to HardcoreZ28 sometime in the near future. Just wanted to let everyone know.
--RPM Racing--
Never used bearing grease, but have used vaseline. Best idea? Preoil the motor. Let me know if you need how to for this. And, no it will not clog anything, and yes, you should change the oil after the initial breakin period. I don't care what the books say...I believe after 30 minutes, 500 miles, 1500 miles switch to synthetic if occasional use vehicle/sports car, or Penzoil if daily commuter.
98Z28 M6 Flowmaster HPP3 K&N
91RS TBI A4 Flowmaster
"recalculated" emissions
do it and you stand a good chance of breaking something. i've used lubriplate 105 assembly lube before, actually everytime i do a rebuild. never had any problems.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
1 Post
Car: 89 IROC-Z
Engine: 383
So you're saying the bearing grease was a really bad idea? It didn't sound that great to me either, but I figured age and experience had my opinion beat. I guess I can take the pump apart and clean it all out.
I have used white lithium grease packed in there before. I have also used assembly lube, and trans gel. Just make sure and change the oil after it runs awhile. I always take a drill and pump it up manually first anyway, so no priming is usually necessary doing it this way.
Axle type bearing grease sounds a little thick and scary to me.
[This message has been edited by Kevin G (edited April 22, 2001).]
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
It really does not need anything. You could set it in oil and spin it but if you prime the motor with a drill before starting the point is moot. I primed a 350 this weekend with a worn out drill all rockers had oil in less than 3 mins.
Anything you put in a motor will change consistancy after the motor heats up. Only lubriplate turns to a liquid that will flow through a oil filter. Molly lube and all others will cause more trouble than they will help.
[This message has been edited by jcb999 (edited April 23, 2001).]
ambainb
04-25-2016 09:21 PM
toronto formula
11-10-2015 06:17 AM
assembly, bearing, engine, grease, greasing, install, installation, installing, intallation, lube, new, oil, pack, packing, pump
