Dyno results: 305TPI, crane2032, Edelbr, dynomax, Haltech etc.
Car: GTA '88
Engine: 420 Dart SHP
Just dynoed 344.1 lbf-ft (466.6Nm) and 262.6 hp at the motor with the mods in sig. I'm very pleased with the results! or what do you think? The torque is great at highway speeds! NO need to downshift at normal passings.
Dyno sheet:
I'm still using the stock 19lbs injectors and they are maxed out! If (when) I want to get more power by somehow i'll have to change them.
-88 GTA 305TPI/T5, 3.42 posi, Crane cams 2032, Edelbrock TES #6872 black satin coated, Dynomax 3" cat-back, ported+portmatched heads, base, plenum, Accel runners, multiangle valve job, no cat, no air, Haltech E6GM ECM. http://www.helsinki.fi/~kjilehto
[This message has been edited by Flfinn (edited April 22, 2001).]
Dyno sheet:
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Looks good....for a 305! Add a small NOS kit, you'll like it even better!!
<font face="Verdana, Arial" size="2">Originally posted by camaro6spd:
nice, i love TPI but i hate how it falls on it's face.</font>
89 firebird formula
360 11.0:1compression (350 .060 over)/fully balnced and blueprinted
comp cams xe262 cam
performer rpm intake/port matched to heads
#1407edlebrock 750
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner/cnc pocket ported
msd 6al/msd8.5 super condutor wires
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
griffin daul1" core rad.cutom fabrication to fit(but no cutting )
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
darwinprice
17
10-11-2015 11:51 PM
LT1Formula
10-08-2015 08:34 PM
