Finally-An answer to the 'buzzing choke light' question
Car: 1986 Z28
Transmission: 700-R4
I was able to get my hands on the shop manual for my '86 Z and while reading through the electronics section, I found the answer to one of my biggest headaches. The Idle Speed Control Relay will buzz for up to two minutes while the car recharges a discharged battery. If it buzzes any longer(like about six months in my case) it means that your battery isn't getting a charge. There are several problems that could cause that-bad diode trio, bad battery, etc, but there it is, in writing, finally. Hopefully this helps a few of you...
1 Post
Car: 99 Formula
Axle/Gears: 342
I just bought a new relay and the buzzing went away. Of course this was the same time that I replaced a bad power steering belt.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
