New engine initial startup and break in procedure?
Well..whaddya do? This is the first I've ever done on a never run engine. All I've done so far is fill it up with 30wt and spin the pump with a pre luber in a drill for a minute or so. I hope to drop it in the car tomorrow, and get it started before too long. Thanks.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
JSP Motorsports
ICON Motorsports
run it between 1300 and 2000 or so changing the rpm, watch for leaks, run a eletric fan to force air thru the radiator. when it gets to temp i shut it down for a little while then start it back up after it has about 30 minutes on it i change oi land filter, then take it for a test drive.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
I like Ed's idead of checking for leaks
What i like to do is run the car for around a 100 miles then dump the filter and add a quart of oil. Some new engines will burn a quart in the first couple 100 miles watch for that.
Also change the oi& filter when you hit 500 miles. Also i like to keep the car under 3000rpm for at least 500 miles. Are you sure you want 30wt? kinda seems a bit thick for a new "tight" engine. or is it 10/30?
[This message has been edited by SUPER-SPORT-CHEVY (edited April 20, 2001).]
run the car at a steady 2000 rpm for about 20 min. have someone do this as you check for leaks, check temp, etc. after this change the oil. Drive at normal pace,dont lug it or rapidly accelerate, for 100 miles. Change the oil. (ya dont need to drive 100 mi all at once but at least get to operating temp everytime) drive the same for 500 mi. change the oil. the rings should be seated now. i usually change the oil again at after 1000 mi and then 3000mi. after the 300o mi oil change HAVE FUN. remeber there is no such thing as changing the oil too much on a new or, espicially, rebuilt motor during break in
dan
i got an 84 camaro, shes got a 89 mustang. which do i have to work on more?
dan
theshackle
09-17-2020 08:26 AM
Zachattack0925
08-12-2015 09:52 PM
