Valvesprings! CompCams 987-16?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Okay, I'm not really concerned with getting new springs for my car as I'm only going to put an LT1 cam into it, but nevertheless if I find a good deal, I may be interested. Will the CompCams 987-16 springs work on stock heads without getting the spring seats machined for extra width?
"1.430 2 spring"
inner diamtere of .697"
121lbs @ 1.800" seat load
388lbs @ 1.200" open load
coil bind at 1.150"
344 lbs/in springrate
"1.430 2 spring"
coil bind at 1.150"
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Your factory spring pocket is 1.26" in diameter. Anything bigger and the pockets need enlarging.
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
the 981,s will work fine with that cam and are stock dia. the 987's will require enlarging the spring pockets.
Eric
Eric
