fuel pump?????
fuel pump?????
i just got done swamping a 2.8 for a 406 carb. and i went to start it and the fuel pump wont even pump whats wrong? its a new pump and filter i put them both on in Nov.????? any help at all please
1988 Camaro RS T-Tops white. Was 2.8 now a mean 406 sbc
(mods)
750 Edelbrock carb
Performer RPM intake
Comp cams Magnum @.50 230-230 lift 480-480
Flowtech 1 3/4 headders with glasspacks for true duals and thats it for now
E.T. 1/4=?
will post when race season starts
2 10' Kicker comps
Kicker 500w amp
Pioneer head unit
2 Jensen 3-way 6x9
along the road
perfomer RPM heads?
NOS
pistons, rods
roller rockers
4.10 rear with posi
91-92 ground effects
yes its in tank style and is there anyway to make it work? what wire could lead to this? would i be able to rig the pump up to turn on when the key is on? and if so how? I need help quick i miss my baby!!!!!!
Car: 1985 Trans Am
Apply voltage to terminal "G" on your ALDL with the key "on". You should hear the pump turn on. If you don't, start by checking your fuses first, then your relay on the driver's side firewall, listen for it to click when you jump terminal G. If that doesn't work, then you have my best wishes at finding where the short is in your electrical system or pulling your pump and replacing it, whichever it might be.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Kevin Irving
ok i did that and it truns on so now what? where is my prob?
(mods)
750 Edelbrock carb
E.T. 1/4=?
2 10' Kicker comps
Kicker 500w amp
Pioneer head unit
2 Jensen 3-way 6x9
along the road
perfomer RPM heads?
NOS
pistons, rods
roller rockers
4.10 rear with posi
(mods)
750 Edelbrock carb
E.T. 1/4=?
2 10' Kicker comps
Kicker 500w amp
Pioneer head unit
2 Jensen 3-way 6x9
along the road
perfomer RPM heads?
NOS
pistons, rods
roller rockers
4.10 rear with posi
Guest
Posts: n/a
I'm assuming the ECM is gone...
I dont know about the 2.8, but the V8 TPI's use an oil pressure switch that will turn the pump on when it sees oil pressure (above 15psi IIRC) and I think Vader said that could be used on a carb setup since by the time the oil pressure comes up it will fill the float bowls back up and you will be ok. Sounds like a decent idea to me. Or you can hook up a switch to the back of that ALDL terminal, but I wouldnt advise that.
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
That's gonna be WAAAYYYY too much fuel pressure for the carb, unless you have a pressure regulator on it! The multi-port on the V-6 will run at around 40 psi, where a carb won't like more than about 7 PSI before the fuel starts running all over the place from the needle valve being unseated. GM makes a pump and regulator for such a situation (used for converting a 305 car the the 350 H.O. crate engine). If you want, I'll track down the part numbers for you, I know I have them here somewhere, because I'm gonna need them!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Working on:
145 MPH IROC Speedo
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
