problem with mallory distributor
i have one of those new mallory hei distributors and am having a problem with the advance. i set the initial to about 16* and only get about 28* degrees at 3200 rpms. no matter what i do i still only get anywhere between 12 and 14* degress of mechanical advance. the advance like hits a brick wall, it just stops. does anybody have one of the distributors and have had problems with them?
Car: 89 IrocZ
Engine: L98-ish
First you need to know what the dizzy is spec'ed for, if you're getting the spec'ed advance, then you'll need a recurve kit, and possibly (dizzy dependant) have to mod the stops for the weights, or the weights themselves.
92camaroJoe
08-13-2015 06:07 AM
