What to put in Radiator
I had to drain the anti freeze out of my car so i could go to the track and i put water in it.Is there anything bad that can happen.I know i'll have to keep filling more often because of evaporation,But what can go wrong with just plan water.
Car: 2006 Silverado 1500
Engine: 5.3L
without it, water pump can fail faster. buy some water pump lube. can be bought at autozone and allows you to run without coolant without water pump problems.
SS,
What track are you going to, anyway? Are you certain you read the rules correctly? I've never heard of a track that doesn't allow a coolant mixture in engines. At the very least they must allow a lubricant and corrosion inhibiter. I would tend to think that they would be exposed to more system failures and coolant leakage in systems that just ran plain water.
I'm confused....
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
I'm confused....
Later,
Vader
"What a Day..."
Guest
Posts: n/a
Actually it's quite common to not allow coolant in cars on race tracks. Coolant (Ethylene-Glycol) is very slippery and doesn't evaporate like plain water. So if someone pukes out some coolant on the track it can lead to wrecks, whereas a little water puked out usually causes no problems. I'm not talking drag stips I'm talking road courses.
Thanks, Flash. My bad...I assumed he meant strips. You know what that makes me
Later,
Vader
"What a Day..."
Later,
Vader
"What a Day..."
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Draining the rad doesn't remove all the antifreeze from the block. When you fill it up with water, there will still be a mixture. I can't remember where a block drain is on a small block. Big blocks have a plug on both sides of the block down near the oil pan rails. It can be a pain if you have to drain and refill every race weekend.
Mission Raceway in BC doesn't allow antifreeze on the track. You need to drain it and use water.
Using the waterwetter is the best thing to add with water for tracks that don't allow glycol stuff. It gives the same heat absorbtion as glycol and gives the water anti-corrosion properties. Plain water will rust the inside of the engine. It's always best to use distilled water in the rad whenever you top it up. The only downside to waterwetter is that it isn't an antifreeze and those of us who live in the northern climates with block heaters on our engines would have to change the fluid during the season changes.
I still use 50/50 glycol in my race car. It's stored outside during the winter, doesn't have a block heater and I don't want the block to crack. If I ever go to Mission BC I'll have to drain it but I don't see that happening for a few years.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
1992 Trans Am
05-10-2023 07:19 PM
ambainb
04-25-2016 09:21 PM
eightsixseven
08-14-2015 03:09 PM
