Front End Noise (Grind/Rattle) like dragging a chain!
Car: "86" Camaro
Engine: 2.8 L V6 MPFI
Transmission: Automatic
I bought an "86" Camaro a couple of weeks ago and have a mysterious noise. When I hit a small bump or pothole I get a lout chatter/rattle noise that seems to come from the front passenger side front. It even does it some times when cruising down the road and I get road vibration. I thought it was an exhaust rattle, but the whole exhaust system seems pretty tight.
Any info would be helpful.
Don1427
Don1427
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
suspension i had the same prob got right pushrod replaced sway bar and bushling < i think thats the word and it solved my problem
not positive that will owrk but it solved it for me
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
interesting, i've noticed the same thing on my car...
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by RB83L69
If it sounds rather like coins jingling in your pocket, it's the sway bar end links.
i was about to post the same thing.
the sway bar endlink bushings erode over time... eventually all thats left is the washers on the bolt... and they jingle.
Terrell351
06-13-2021 01:13 PM
ambainb
04-25-2016 09:21 PM
